Boutique Nike : -25% dès 50€ sur TOUT le site Nike avec le code ...
 N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]
18 participants
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Empty
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeDim 29 Jan 2017 - 6:56
Avec les photos c'est mieux !
Voila où j'en suis
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 05313
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 05413
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 01_gb_10N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 03_gb_10N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 05_gb_10N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 06_ope17 N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 09_gb_11
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeDim 29 Jan 2017 - 7:34
J'attend le final avec impatience N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 1341529484
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeDim 29 Jan 2017 - 8:16
On est deux !!!!
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeDim 29 Jan 2017 - 10:51
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 3691603751 chouette alu!
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeDim 29 Jan 2017 - 11:00
Merci pour vos appreciations
L'extrados a reçu, lui aussi, sa couche de TS-30. Reste plus qu'a bien laisser secher, traquer les eventuels defauts et je pourrais commencer le panneautage
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 05513
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeDim 29 Jan 2017 - 11:10
Propre, net et sans bavures !
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeDim 29 Jan 2017 - 12:19
Topissime.
Devrait pas y avoir beaucoup de chose à reprendre....
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeLun 30 Jan 2017 - 8:32
Ha pas mal !!! Tu n'as pas fais la verrière ? coller/peindre la partie avant et peindre l'arrière. Ce qui supposerait d'ailleurs d'avoir peint/collé la partie haute du TdB
D'ailleurs un truc... je n'arrive pas à savoir s'il convient de peindre ou pas ce qui me semblent être des cordons de détonation...
Et tu peintures les pneus ? c'est pas gênant de mettre de l'alu sous la couche de noir pneus ?
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeLun 30 Jan 2017 - 12:35
Hello Florent,
Je vais essayer de repondre dans l'ordre
Habituellement, je masque et j'installe pare/Verriere. Mais justement, je ne sais pas encore trop comment je vais traiter ces "rayons" dans la verriere.
Pour le TdB, je ne l'ai pas installé car justement, je n'ai posé le pare brise. C'est un coup a casser ou abimer ces pieces
Comme je le dis juste au dessus, je ne sais pas non plus comment je vais m'y prendre. L'idée premiere, comme ça, a chaud, ce serait peut etre un brush leger au Rub'n Buff pour les faire apparaitre ...
Pour les roues, je procede comme ça. Peinture aero, ou bombe des roues, puis les pneus. C'est pas genant, meme avec le TS-30, ou équivalent (TS-17), dans la mesure ou on peut s'en servir comme apprêt, enfin, ca m'arrive de m'en servir ainsi, selon le besoin !). Il faut juste bien laisser secher, au moins 24.00
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeLun 30 Jan 2017 - 13:39
ok, grand merci à toi ! je vais me lancer alors ! Il me semble avoir vules cordons peints en blancs, au 1/32. je vais tâcher de m'y coller
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeLun 30 Jan 2017 - 14:50
Effectivement, c'est bien du cordeau. Le blanc, ca peut le faire ou un gris clair
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 F86d_010
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 F86d_011
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeLun 30 Jan 2017 - 15:14
Ha bien vu !!!! j'ai pas réussi à trouver si bien comme photos... gris clair serait plus juste sans doute mais j'ai peur que ça ne se voit pas assez. d'où le blanc.. un blanc sali ? un peu de marron (99/1) ?
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeLun 30 Jan 2017 - 22:17
Super la peinture est très belle Sleep Sleep
Bonne suite Tittou.
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 8:12
Bravo à toi aussi, il a bien avancé..
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 8:40
Oui Florent, gris clair ou un blanc cassé au brun, mais bien leger comme tu le dis, ca doit le faire
En attendant de m'occuper de ça, j'ai posé les durites sur les jambes du train principal
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 05713
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 8:50
Hello Titou
C'est fort joli tout ça.
Par contre,pas simple pour la verrière....
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 12:14
Justement, cette histoire de cordeau dans la verriere, ca me turlupine depuis qu'on en parle. Alors je m'y suis collé.
J'ai testé un brush leger avec un melange d'huiles : Argent incandescent, et un soupçon de TSB. j'aurais peut etre pu brunir un peu plus, mais l'idée est là
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 05814
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 05913
Par contre, c'est pas simple a photographier. En réel c'est plus marqué que cela
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 12:19
ha oui c'est plus subtil que ce que j'ai fait. à revoir comment j'ai procédé c'est un jus-technique-bourrin que j'ai mis en place. j'aurais dû faire un jus, ça m'évitait de tout salir.... je trouvais dommage, quoiqu'il en soit, de ne pas les traiter (comme c'est le cas sur tout les montages que j'ai vu jusqu'au 48).
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 12:33
C'est pour ca que j'ai testé le brush. Comme ça ne se fixe que sur les aretes, j'avais plus de chance que la verriere reste propre.
Sinon, j'ai vu aussi un monteur procéder par masquage de la verriere, par l'interieur, bien sur, et passer un coup d'aero sur les lignes ... drunken N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 1429875572
Bref, je n'imagine meme pas essayer !!!
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 12:40
Les durites de freinage sont peintes, et à part les jus à venir, je ne retoucherais plus ces pieces
N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 06013
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 12:42
parfait !
pour le masquage j'ai essayé, je n'y suis pas arrivé... je viens de voir que tu as fais un brush, pas un jus. le brush je n'y suis pas arrivé.
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 12:44
Faut y aller vraiment leger leger, et bien evidement, y revenir inlassablement, bien des fois !
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 12:46
mon erreur a été d'utiliser de la peinture, et non diluée. elle sèche sur le pinceau, avant d'avoir pu se poser. j'ai brossé 10 minutes sans réasultat probant
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 13:06
Pour les mes brushes, je n'utilise que de la peinture a l'huile, que je depose sur un papier ou un carton, pendant quelques minutes. Ca "eponge" le solvant et ainsi j'utilise au maximum les pigments.
Avant de brosser, j'essuie mon pinceau jusqu'a ce qu'il n'y ai plus, en apparence, de peinture.
Lorsque je passe le pinceau sur la piece a traiter, les aretes "viennent chercher" les pigments residuels qui s'accrochent a l'endroit concerné.
Si je frotte sur une surface lisse, il ne se passe rien
MessageSujet: Re: N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C]   N.A. F-86E "Sabre" - 1/72 - Academy [M.E.C] - Page 6 Icon_minitimeMar 31 Jan 2017 - 13:17
ouais c'est paske j'ai pas pris de peinture à l'huile je pense. ça n'a pas du tout eu le bon comportement avec la tam. enfin je pense. parce que pour la méthode je fais bien comme ça
Page 6 sur 10Aller à la page : Précédent  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Suivant
»  N.A. F-86F "Sabre" - 1/72 - Academy
» N.A. F-86F "Sabre" - 1/72 - Academy [M.E.C]
» N.A. F-86E "Sabre" - 1/72 - Academy
» NA F-86K Sabre KH 1/32
» SABRE SUD-AFRICAIN
SCALEMODEL :: MONTAGES EN COURS / WIP :: RÉALISATIONS GUERRE DE CORÉE (1950-1953) :: AIR-
